Старый 27.02.2013, 09:42   #1
Das Auto - нет
По умолчанию VAG COM и Golf VII
Думаю можно начинать потихоньку разбираться.
Скан:
VCDS Version: Beta 12.10.2
Data version: 20121222
Chassis Type: 5Q0
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: WVWZZZAUZDW063437
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CRBC) Labels: 04L-906-021-CRB.clb
Part No SW: 04L 906 021 DS HW: 04L 907 309 D
Component: R4 2,0L EDC H22 4941
Revision: 83H22---
Coding: 01190012032405082000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_ECM20TDI01104L906021DS 002008
ROD: EV_ECM20TDI01104L906021EA.rod
VCID: 79F92347F8C17BD6CF3
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
Part No SW: 5Q0 907 379 P HW: 5Q0 907 379 D
Component: ESC H75 0434
Revision: 00000000 Serial number:
Coding: 01FA62A120260A6F037B060301CA2980460450C0608094F300 680024C0
ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
VCID: 49999387E8A12B561F3
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 5G0 907 044 R HW: 5G0 907 044 R
Component: Climatronic H02 0503
Revision: 00001K06
Coding: 00020104202100011005000000101000
ASAM Dataset: EV_ACClimaBHBVW37X 002017
ROD: EV_ACClimaBHBVW37X_SE37.rod
VCID: 3663E87B895F54AE621
Fresh Air Blower Front:
Refrigerant Pressure And Temperature Sender:
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 Q HW: 5Q0 937 084 Q
Component: BCM MQBAB H H14 0106
Serial number: 00011300300967
Coding: 00000A46C24122FB4FE44000001C0708100A00000000000000 0000000000
ASAM Dataset: EV_BCMCONTI 010001
ROD: EV_BCMBOSCH_VW37.rod
VCID: 468398BBF9BFC42EF21
Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 B HW: 5Q0 919 294 A
Component: PARKHILFE 8K 002 0026
Revision: -------- Serial number: 94231300307854
Coding: 0031051001
ASAM Dataset: EV_EPHVA18AU3700000 002016
ROD: EV_EPHVA18AU3700000.rod
VCID: 3A7BFC4BBD47B0CE869
Address 15: Airbags (J234) Labels: None
Part No SW: 5Q0 959 655 C HW: 5Q0 959 655 C
Component: AirbagVW20 011 0361
Serial number: 003F5R01XN0L
Coding: 98CCC000000000005C0000CF004800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 408F8EA3DB9BEA1EC8D
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 AA HW: 5Q0 953 549
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 19121208490250
Coding: 0400
Shop #: WSC 40195 333 37120
ASAM Dataset: EV_SMLSKLOMQB 009001
ROD: EV_SMLSKLOMQB.rod
VCID: 75E12F77D4D91FB6ABB
Address 17: Instruments (J285) Labels: None
Part No SW: 5G0 920 860 A HW: 5G0 920 860 A
Component: KOMBI 236 0555
Coding: 07A401002B80000800082A00040000
ASAM Dataset: EV_DashBoardVDDMQBAB 008026
ROD: EV_DashBoardVDDMQBAB_AU37.rod
VCID: 2643383B59FF242ED21
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 5Q0 907 530 F HW: 5Q0 907 530 F
Component: GW MQB High 122 1109
Revision: -------- Serial number: 0000199322
Coding: 030100040B087300EF00024A080F0001000100000000000000 0000000000
ASAM Dataset: EV_GatewLear 006010
ROD: EV_GatewConti_VW37.rod
VCID: 3467D2739F2346BE5C5
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
Component: TSG FS 012 0006
Serial number: 12121200091072
Coding: 003B0320D000040000001000
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 3F8D8D5FA66595E6B17
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Coding: 01
ASAM Dataset: EV_SteerAssisMQB 008022
ROD: EV_SteerAssisMQB.rod
VCID: 3D71F757AC6987F6A3B
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 19111200011014
Coding: 003B0120DE00040000801000
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 3E73F05BA16F9CEEBA1
Address 55: Xenon Range (J745) Labels: None
Part No SW: 7P6 907 357 A HW: 7P6 907 357 A
Component: AFS-ECU H07 0080
Revision: -------- Serial number: --------------
Coding: 029A00000B000200
ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
ROD: EV_HeadlRegulVWAFSMQB.rod
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 5G0 035 819 HW: 5G0 035 819
Component: MU-S--ER 039 0142
Serial number: V1C02812120580
Coding: 02730000FF00000011110001000800001F0100840100010001
ASAM Dataset: EV_MUStd4CPASE 002036
ROD: EV_MUStd4CPASE_SK37.rod
VCID: E6C3F83B197F642E921
End ---------------------------------------------------------------------
Большое количество кодировок
Активация функции Coming Home (провожание светом, 40с)
Полная расшифровка битов блока бортовой сети
Включение сигнала (пиканья) при открывании и закрывании
Включение опускания правого зеркала в положение видимости бордюра при включении задней передачи
Отключение проверки подсветки номера
Включение теста стрелок
Включение закрытия окон при дожде
Включение Coming и Living Home через противотуманки
Отключение сигнала о не пристёгнутом ремне безопасности
перенастройка педали газа
активация подсветки ног
изменение яркости приборки
Расшифровка ламп в адаптации, вот она:
лампы::
Leuchte0BLK VLB36 Левый передний поворот
Leuchte1BLK VRB20 Правый передний поворот
Leuchte2SL VLB10 Левый передний габарит
Leuchte3SL VRB21 Правый передний габарит
Leuchte4TFL LB4 Левый передний ДХО
Leuchte5TFL RB32 Правый передний ДХО
Leuchte6ABL LC5 Левый ближний
Leuchte7ABL RB1 Правый ближний
Leuchte8FL LB39Левый дальний
Leuchte9FL RB2 Правый дальний
Leuchte12NL LB45 Левая передняя ПТФ
Leuchte13NL RB5 Правая передняя ПТФ
Leuchte18BLK HLA60 Задний левый поворот
Leuchte19BLK HRC31 Задний правый поворот
Leuchte20BR LA71 Тормоз левый
Leuchte21BR RC8 Тормоз правый
Leuchte23SL HLC10 Левые задние габариты
Leuchte24SL HRA65 Правый задний габариты
Leuchte25KZL HA59 Подсветка номера
Leuchte26NSL LA72 Левая задняя ПТФ
Leuchte27NSL RC6 Правая задняя ПТФ
Leuchte28RFL LC11 Левая задняя фара (при движении назад)
Leuchte29RFL RA64 Правая задняя фара (при движении назад)
Leuchte30FR LC72 Освещение ног
действия, которые можно повесить на какую-либо из ламп
действия:
Blinken links Hellphase – работает при загорании левого поворотника
Blinken links Dunkelphase – работает при притухании левого поворотника
Blinken rechts Hellphase – работает при загорании правого поворотника
Blinken rechts Dunkelphase — работает при притухании правого поворотника
Blinken links aktiv (beide Phase) – работает постоянно при работе левого поворотника Blinken rechts aktiv (beide Phase) — постоянно при работе правого поворотника
Standlicht allgemein (Schlusslicht, Positionslicht, Begrenzungslicht) – Горит в режиме габаритов
Parklicht links (beidseitiges Parklicht aktiviert li & re) – горит в режиме парк. огня лев.(заж. выкл.)
Parklicht rechts — горит в режиме парк. огня прав.(заж. выкл.)
Abblendlichts links – горит при ближнем левом огне
Abblendlicht rechts — горит при ближнем правом огне
Fernlicht links – горит при дальнем левом огне
Fernlicht rechts – горит при дальнем правом огне
Lichthupe generell – включается при моргании дальним
Nebellicht links – горит при включении левого птф
Nebellicht rechts – горит при включении правого птф
Tagfahrlicht – горит при ДХО
Bremslicht – горит при нажатии на тормоз
Rueckfahrlicht — горит при заднем ходе
Nebelschlusslicht – горит при включении заднего птф
Heckdeckel offen – загорается при открытии багажника
Heckdeckel geschlossen – загорается при закрытии багажника
Dimmung klemme 58xs – регулируется яркость регулятором из салона
Innenlicht — (по идее должен зависить от внутреннего освещения) но плавно вкл. При откр. двери
Kofferraumlicht – горит при включении света в багажнике (при откр)
Последний раз редактировалось BeaViS; 07.07.2015 в 14:59.
25 пользователя(ей) сказали cпасибо:
71miha71 (08.11.2021), ABBA (18.09.2013), alexyu (19.04.2015), Andy555 (23.03.2014), avtoexpert18 (25.03.2014), Bedal (11.11.2016), dip27 (05.08.2013), evgen-212 (05.04.2014), excalibur (14.12.2014), infiniti8.8.8 (23.12.2015), Krash123 (25.01.2016), leks (26.08.2013), lexa 738 (05.11.2013), LikeNo0ther (07.04.2014), logindm (24.08.2015), Piligrimroman (07.10.2019), qwepp (07.10.2015), Romiuz (23.03.2014), Rusik (20.11.2015), salimbo1982 (07.11.2014), Sergofan (28.11.2013), Vinsent (04.10.2016), yuri0702 (04.02.2014), ZAXXX (17.02.2014), Юрник (03.04.2016)
Старый 31.03.2013, 23:34   #2
Аватар для mexanicka
Das Auto - Golf 6 GTI
да, забавненько.
25 адрес исчез, зато в 17-м длинное кодирование
подрулевой 16-й стал короткий, да и сам рейка 44 - вообще 2-значный код.
появился 5Ф - не вполне понятно, что там
Интересно покопаться в 3 адресе - там теперь электроручник живет
Короче, платформа действительно изменилась...
Старый 09.04.2013, 20:08   #3
Аватар для WhiteGolfVI
Сообщение от mexanicka Посмотреть сообщение
да, забавненько.
5F у Ауди MMI 3G
WhiteGolfVI вне форума   Ответить с цитированием
Старый 13.05.2013, 16:23   #4
Das Auto - нет
По умолчанию Опускание правого зеркала при включении заднего хода
Блок центральной электрики 09
16 Security acsess - ввести 31347
10 Adaption
в группе Central Locking Control Adaptation 2
канал Spiegelabsenkung bei Rueckwaertsfahrt: изменить на active
канал Menuesteuerung Spiegelabsenkung: изменить на active
Блок пассажирской двери 52
07 кодирование
байт 4
активируем бит 2 и 3
Но не всё так просто
Версия блока двери должна быть не 012 0006, а 007 0006. Иначе
Последний раз редактировалось waskadagama; 03.12.2013 в 11:15.
Dizzzzz (22.08.2015), halin_nikolay (06.08.2013), Jack (02.04.2014), SPH (17.06.2013), Tolik_boxer (10.11.2016), yuri0702 (04.02.2014)
Старый 29.07.2013, 11:22   #5
Das Auto - нет
По умолчанию Включение теста стрелок
Панель приборов (Schalttafel) - блок управления 17
Адаптация (Anpassung) - функция 10
Выбираем канал - Inszenierung
aktiv
Последний раз редактировалось waskadagama; 29.07.2013 в 11:39.
ABBA (18.09.2013), Andrey.cz (29.05.2014), dip27 (05.08.2013), Dizzzzz (17.12.2013), Krash123 (02.01.2014), paren-na-kamaze (27.08.2013), soccer31 (13.12.2014)
Старый 29.07.2013, 22:59   #6
Das Auto - Skoda O2
Отключение ремней безопасности (напоминание):
Schalttafeleinsatz - 17
Anpassung - 10
Gurtwarner deaktivieren auswählen
ja
mmi вне форума   Ответить с цитированием
Старый 01.08.2013, 20:20   #7
Das Auto - G7 1.4
По умолчанию Тест стрелок.
А можете подсказать номер канала для включения теста стрелок?
По тому что на английской версии не могли найти(11.11.6).
Buena Suerte вне форума   Ответить с цитированием
Bednarzh (26.06.2018)
Старый 02.08.2013, 10:33   #8
Das Auto - нет
Buena Suerte, indicator celebration
Старый 02.08.2013, 21:34   #9
Das Auto - G7 1.4
waskadagama, спасибо, не не помогло. Нет ничего подобного. Смотрели ребята с сервиса, не могут найти ничего подобного.
Может есть различия для приборок? Но у меня такая же как на видео.
Или можете сказать какой бит и байт?
Старый 02.08.2013, 22:37   #10
Das Auto - Skoda O2
надо номер канала адаптации и его значение
Старый 05.08.2013, 08:39   #11
Das Auto - Golf 7 1,4 tsi 140 highline
Господа, а про разблокировку видео в движении на дисковер про, кто-нибудь может что-то сказать? Может кто делал?
Golf 7 1,4 TSI 140hp highline. Есть все что можно было взять))
youseem вне форума   Ответить с цитированием
Старый 10.08.2013, 08:43   #12
Понятно...
Старый 14.08.2013, 20:05   #13
Гость
Немчура на MotorTalk пишут, что смогли отключить Старт-Стоп, вот таким шнурком
http://www.diagnoses.biz/index.php?i..._id=25&lang=DE
Старый 15.08.2013, 09:17   #14
Аватар для SPH
Das Auto - Т150
Цена вопроса с доставкой EMS 340 евро. Ломаных нет, китайских копий тоже не встречал. А так отличный инструмент.
Здесь могла быть моя реклама
SPH вне форума   Ответить с цитированием
Старый 22.08.2013, 01:19   #15
Кто знает, почему VAS PC 19.22 (30/04/2013) не знает про Гольф 7?
Что использует дилер для семерок? Новую прогу?
Старый 22.08.2013, 09:29   #16
Das Auto - нет
почему не знает? Знает. Через самодиагностику.
А у дилера... У дилера - ODIS
mexanicka (22.08.2013)
Старый 22.08.2013, 16:42   #17
я тут попытался "прикрутить" радар адаптивного круиза от семерки к своему коню.
VCDS видит 13 блок, но поскольку для VW36 нет ROD-файла, то нет ни расшифровки ошибок, ни расшифровки битов в кодировке. В расширенных свойствах обнаружен VIN донора. Соответственно, отсюда начинаются проблемы/ошибки. Хотел попробовать подружить блок с моим автомобилем. В VAS PC самодиагностике он изначально видит блок 13 с ошибкой, но при попытке к нему обратиться пишет блок отсутствует и он исчезает из списка.
Старый 23.08.2013, 01:51   #18
А drive select на mqb еще никто не включал?
pav089 (07.02.2016)
Старый 23.08.2013, 09:48   #19
Das Auto - нет
Jump, без адаптивной подвески эта функция одно баловство.
Но включается , думаю по такому же принципу как на Ауди 8K
Последний раз редактировалось waskadagama; 23.08.2013 в 09:50.
Старый 23.08.2013, 10:15   #20
Аватар для zloybob
Das Auto - audi
waskadagama, так на седьмом нету же адаптивной подвески
вот наверно драйв селект второе, что после отключения старт-стоп я хочу себе)
sai-99 (22.08.2014)
Текущее время: 18:33. Часовой пояс GMT +3.
